fyreduck1921
- Aug 24, 2013
- 17
I recently bought a 76 Bronco Sport and have put a few hundred miles on it, but very few at night. The other night I started it up and the both low beam headlights went out when I pulled out the headlight switch. The high beams work fine, and the parking lights work fine. However, when the headlight switch is pulled all the way out (headlights on) and the dimmer is in the low beam position, the headlights don't come on and the voltmeter jumps all over the place. The voltmeter reads normal with the high beams on, or just the parking lights on. I replaced the dimmer switch, and that solved the problem until the 3rd time I turned the headlights on. Now I am right back to where I started; no low beams and voltmeter all over the place.
What could the cause be?
Thanks,
Steve
Thanks,
Steve
