Have a '76 Bronco 302 in California.
Prepping for Smog. Warmed her up and noticed the Temp Gauge was pegged. Did some Googling and decided to test uplugging it then turning the key 'on.' With it the sensor plugged, and unplugged the need pegs to the right. I assume original cluster. Other temps/alternator works fine. Could this be due to a low battery or is this too old of tech to misread due to low/no voltage?
EDIT - Need goes full 'off' (left) when ign is off. Just pegs with or without the sensor connected (full right,) when acc/engine is turned on.
Easiest way to fix this? Id like to keep the cluster. Is it possible to rerun a wire from the sensor to inside the cab and just pull out the cluster a little and connect a new wire?
Other tests I can perform as a newbie of sorts?
