Ok. I rebuilt the engine and we had the engine running prior to taking it in for body and paint. We hooked everything up with just the ignition switch wired up. I did this for the mechanic and paint guys to be able to move it around the shop. However, it took the paint guy 4 extra months to complete the paint project. Needles to say, at some point, the bronco would not longer fire up. Basically, all I get is the......."WAAA WAAAA WAAAA" sound. I have fuel to the fuel filter and fresh gas. I emptied the gas tank, cleaned it out, and now have 5 fresh gallons of gas in the reserve tank.
Ok, here is what I have for readings from the battery, starter relay, and coil. I hope you guys can help me out before I call a real mechanic.
All of these readings were with the key in the "ON" position. Also, my coil was extremely hot if that makes a difference after only 20 minutes of trying to fire it up. I'm thinking at some point the paint guys moved the car and left the bronco key in the "ON" position and burned up the coil. I can't prove anything though. The coil doesn't have a ballistic resistor because supposedly it didn't need one. I'm running the original ignition module and distributor if that makes a difference. If I go back to a coil with a ballast resistor, the ballast resistor goes between the wire that goes to the starter relay, correct?
Lastly, as my negative I used the negative of the battery for all these readings. Also, I have a high torque starter if that makes a difference.
Battery
12.58v
Starter Relay
Right to Left on Starter Relay The parenthesis denotes what wires are connected. Again, it ran when I took it to the paint guy.
X(Goes to + of battery) X (Ignition switch) X(to + coil/starter) X(Starter)
12.61v .01v .01v .23v
Coil
12.21v 1.35v
Coil Ohms (Across + to - )
.223
Thoughts? Shouldn't my Coil NEGATIVE be in the 6v range?
Thank you sooooo much in advance,
TexasDude
Battery
12.58v
Starter Relay
Coil
12.21v 1.35v
.223
TexasDude
