UPDATE:
Wooohooooo! It's alive!
So I decided to check my valves first so I turned to TDC and man did I cinch those things down!! I obviously didn't have a very soft touch! As I let out each one I could see the valve springs lift up so that's where my compression was going. After adjusting them all it cranked over beautifully and started right up! Man what a good feeling, the cam, headers, and duals make it sound sooo much better!
I'm still not sure I have the valves dialed in perfect. I guess if they are too loose ill here them tapping. Any indication if they are still too tight? Of the three types of stock ford valve trains this ones seems the hardest to get right because there is no torquing down the nuts, or measuring the lash.
Another question I have is I'm about to install my electric choke wire on my edelbrock 1406. I'm going to splice it into the red/green wire from the regulator but I want to know what the best way to splice the choke wire into the middle of the green/red wire.
You guys are awesome!!! I wouldn't be this happy tonight without all your help! Gonna break out the Johnnie Walker Blue label!!
