77 half cab question?
joshuar6447
spotsylvania
I'm building. A 77 bronco and I'd like to make it a half cab. I got to looking last night and my driver side inner quartet is different. My question is, do I need to modify the bulk head m or the quarter pannel post? I have a really nice bulk head and figured I'd ask before I started going to town with the hammer. Thanks in advance
joshuar6447
joshuar6447
spotsylvania
Current state moving slowly
blubuckaroo
Grease Monkey
Ridgefield WA
You could try to get a photo of someones '77 bulkhead. I realize that Ford quit making half cabs for the general public before this but they did continue to make them for govt contracts until the end of production. There was one here used by the county for mosquito abatement.
joshuar6447
joshuar6447
spotsylvania
There are alot of them out there and I wanna say 71 was the last production year. Again I came here before I went to beating and cutting. 77 is the only year with different inner fender wells on the drivers side
Shouldn't matter that much I wouldn't think. Been wrong about '77's before though!
The change was for the fuel doors of course, but in '76 they also lost the condensing tank behind their too.
Is the total shape of where the bulkhead mounts different? How's about a picture of the spot in question?
Are you asking because the profile of the panel isn't close to matching the bulkhead anymore, or because you're not sure if drilling in that are is ok?
joshuar6447
joshuar6447
spotsylvania
I will get a picture tonight. And its totally different. The pass. Side is the same with the piece the slopes down for the side mounting pieces. But the drivers side starts to slant then has a box where the fuel cup goes. I could bend the drivers side mounting tab in and make it work probably. I just don't want to ruin a great original bulk head.
Ok, I see now. I had seen them before, and thought there was still some slope there, but didn't realize that they'd cut it way back.
Still looks do'able to me though. Instead of modifying the bulkhead, why not just add a small piece of sheet-metal in the upper portion of the angled wall to sort of extend it back just a bit.
Would that work?
joshuar6447
joshuar6447
spotsylvania
The entire inner fender is boxed in flush with the slant and outer portion of the inner fender. So its either cut the inner fender out or bend the mounting tab on the bulk head. I have a bulk head that's kinda crappy that I may try first
Anything that's boxed can still have riv-nuts inserted into it, if that's what you're wondering. Even big sheet-metal screws would hold pretty tight.
Aren't the threaded holes in the body, and the bulkhead just has holes? Or is it the other way 'round, and you're expected to reach in behind and run a bolt from the back?
Wouldn't surprise me of course, but I thought I remembered threaded inserts on the body side of things.
Anyway, good luck with it. Good idea to use the less desirable bulkhead for your fittings.
joshuar6447
joshuar6447
spotsylvania
Here are a few more pictures of a bulkhead notice attatching tabs left and right side. and then where and how it installs. on the 77 inner fender there isn't spot to bolt it unless you cut the bulk head or fenderwell.
Ok, sorry you had to spend so much time trying to show the blind!
I'd forgotten that the fasteners were on the backside of the body panels. I was thinking that they faced inward towards the seats.
Yeah, gonna leave some marks it looks like.
joshuar6447
joshuar6447
spotsylvania
Yeah I have an idea what ill Di. Just seeing if anyone's already done it. Probably goin to make a cut and bend a portion in to mount on the side
half cab
Guru Bronco
My cousin did this for me back in '78 and I clare it's been so long I forgot what we did to make it work..We put a '69 halfcab and bulkhead on a '77..He's dead now so can't ask him...
