77 Knuckle Buster Build 03 - 01
Bukin 67
Bronco Abuser
Looking good OB21. I don't think I could have wrapped myself around restoring a Bronco recovered form the bottom of a lake with the kinds of issues that result from the rust and water damage. Great job you're doing, keep it up. You're certainly an inspiration to others for the love of the build.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
I find myself using parts that I would have not used 10 years ago. Yes I am better at restoring them but its getting harder and mor expensive to find the cleaner parts. It just takes longer in the end, I guess more bonding time with the Bronco. lol
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Working on the bottom of the tub.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Cut out the quarters. I had to air chisel most of it out because I could not locate the spot welds (they were covered by rust and undercoating.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Under coated the bottom with bedliner and began fitting a quarter panel. Yes the picture is upside down, lol
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Well I got the quarter panels welded in also seam sealed and painted them on the inside. I also drilled out my door post and fixed them so they are now adjustable again. I hate painting over the old door post (the part that goes in the latch).
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Some epoxy sealer on some parts now. Still have loads of body work and am waiting on a rocker to replace.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Been a bit since I updated. I have been tackling the Body, Doors, Tailgate, hood and taking apart an engine and getting it running. Had the engine fired and running tonight on the frame. The body has been primer sealed and body work slow going. I am building some half doors right now and plan to make inserts for them. My goal is to get this thing in a few coats of high build primer, sanded and painted before October. Also I need to pull the c4 off the engine and get it rebuilt. Seems like I am working on 50 projects at once on this.
Blue Bastard
Looks like you are making a lot of progress. Did you say what color you are going with?
rocky road
chatsworth Ca.
parts help
Good to see you get another bronco. If you need any parts I have plenty of New and used parts to help you cherry it out Rocky Road aka Lee 818 280 3593
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Been trying to get the paint on this thing.
