- Oct 11, 2007
- 445
So I wanted to ask what you guys think or have run into in your own builds.
I am using my c4 and dana 20 out of my 77 in my 66 build for the time being. I’m using a 94 5.0 with explorer efi. Started installing the motor and the torque convertor studs wouldn’t line up with holes in flexplate. Pulled engine back out and found this.
Torque converter has a 10.5 bolt circle. Flexplate has a 11.5 bolt circle. I have owned this 77 since it was new. I have replaced the transmission and engine once but the flexplate is the original 77. So I haven’t had any issues with flexplate to torque convertor comparability. So to my mind it came from ford with the 10.5 164 tooth flexplate. From what I am finding (on threads here) ford went to the 164 tooth 11.5 flexplate by 1977.
I’m just curious if you guys have seen this before?
