'77 vapor emission plumbing
jckkys
When new, my '77 had a 2150 carb with a vent nipple on top of the float bowl. The vent was capped off, as was one of the small nipples on the charcoal canister. Since it was just federally emission compliant, I always wondered if Cal. emission rules would have required the float bowl vent to have a hose to the canister. The other small nipple on the canister vents the fuel tanks.
I'm thinking that fuel vapors would be pulled out of the carb after the engine is shut down, saving some fuel and easing the over rich restarts. The larger corrugated aluminum hose from the air cleaner does pretty much the same thing so it must be effective for vapor that flows back into the air cleaner.
spap
My 77 has the small vent lines from the tanks to a one way valve on the frame rail to the charcoal canister on the frame rail behind the pass side*tire. The charcoal canister has 3 nipples on it. One small inlet for the vents on the gas tanks, one inlet for fresh air to enter the charcoal canister has like a mushroom type cap and one outlet to the air cleaner.
My CA truck never had a vent from the carb to the cc but it was a mid year 77.
jrwyant
The carb. in my CA '77 lacks the bowl vent too. (You can see where one would go, but it has a pressed-in plug. Wasn't implemented.)
I'll check my vapor cannister, but I think it's the same as the above.
J
jckkys
Thanks. The vent on my 2150 carburetor had a rubber vacuum cap but by removing that a 1/4" hose goes right on and it points at charcoal canister, hanging from the fire wall, that also has a small nipple that is capped.
By the '80s all carbureted Fords had vents on the fuel bowls that were plumbed to the charcoal canisters. Usually these had purge valves in the line. I don't know if these are needed. It seemed logical that at least in some locals a hose would be run from the float bowl to the canister. Without it the fuel vapor builds in the carb, intake, and air cleaner, after shutting down a warm engine. To start the engine requires cranking to bring in air till the engine can fire up. If this fuel can go back in the fuel tank it can be used to run the truck later instead of wasted.
Interesting discussion for me. Never seen a '77 hereabouts that didn't have the plastic canister on the firewall, vs the earlier steel one on the frame. Also never seen a factory original carb that didn't have the nipple plumbed into the canister.
Now, I've seen boatloads of replacement carbs that either didn't have the bowl vent, or had it plugged, but always saw them connected in earlier years. Not sure about nowadays, but for a long time it was often quite difficult to find a compliant carb with the vent fitting as a replacement. They all seemed to be earlier vent-less types, or plugged like jrwyant's above.
Be interesting to see what month your rigs were built, or what order VIN numbers put your rigs in. That '77 was a strange year for EB's for sure. We did a poll a few years ago looking for the change-over date for things like the charcoal canisters and the parking brakes and such, but I thought we found that the plastic canister was found on some very late '76 models. Must be my memory fooling me though, if you guys have '77's with the steel tank. Then again, our shop '76 has the later plastic canister, so maybe it's a CA vs FED thing after all.
You mind posting up your build months?
Maybe your DSO's too?
jrwyant
My VIN is U15GLY77228; DSO is 72 (San Jose?). I have something that says it was shipped to Redding, I can't find it right off though.
My (presumed stock) carb. tag says
D 7 T E
ABA
C 7E 4
(something like that.) Is it maybe not the original?
Oh, and I've got the plastic charcoal canister with the four nipples on top: two small ones on the left (front one capped, back one from rear/aux. tank vent), middle big one to air cleaner, and big right one with the "mushroom" cap.
-jesse
Cool. Thanks for the info. Do you still have the door jam sticker with the build month listed? Some get painted over, some just deteriorate. But a lot of them stay in good shape too, so hopefully yours is.
I know others can tell the build (probably right down to the day) with just the VIN, but I never memorized that stuff.
The D7T tag on the carb says that at least the tag is from a '77 truck. Still could have been changed at some point and they just put the old tag back on. It's practically a miracle that the tag is even there! Most get tossed-and-lost by the time the trucks were getting into their teens.
Theoretically at least, that second capped nipple on the canister would have been from the bowl vent, that you don't have.
J
jckkys
Paul's statement that all the '77s he saw, had the float bowl vent plumbed to the charcoal canister, confirms my suspicion that Cal. emissions required that. Like so many other options Ford provided some of whats needed to go either way. In this case a simple 2' length of hose was a couple cents more than 2 vacuum caps. The corporate bean counters won't spend a penny they don't have to.
In my case, the hose may help remove fuel vapor, that because of the over rich mixture, makes hot restarts less than instant, if the truck sits for a short time. As a bonus, I keep that fuel to be burned later pushing me down the road.
jrwyant
I finally remembered to check my sticker. Says June. So, plastic carbon canister, no fuel bowl vent.
-jesse
Cool. That certainly makes it one of the later-built '77's and nearing the end of the run.
I forget what month was actually last, but you're up there close.
