77 wiper wiring Question
eds66bronco
Essex, Vermont
the last thing i ned to figure out is the the wiper wiring. from the harness to the wiper motor there are 5 wires. 1 goes to the dome light and the other 4 to the wiper motor (red, black, blue, white). i have a set of toms marine type replacement dual motors that had it's own switch. i want to wire this to the stock switch and have figured out all the connections but 1. i have two speeds and park, but the 77 motor plug red wire is the only one i can't figure out. it has 12v run/acc power. what was the funtion of the red wire to the motor?
70_Steve
Old Guy
Looks like the red wire supplies power to the wiper motor so it will run to the Park position when the wiper switch is in the Off position. A switch in the wiper motor connects the Red to the Black/White wire when the motor is not in the Park position. When the wiper switch is in the Off position the Black/White is connected to the White/Orange low speed connection, so the wiper motor will run to Park, then open the motor internal switch so the motor stops in this position.
Here's a link to the wiring diagram on N8's Site.
http://www.wsu.edu/~i6735189/75_77wd9.gif
