Broncopower96
A mechanic and I rebuilt the 9 inch rear end this afternoon. Installed a true trac and 4.56 gears. When we attempted to press on the new axle bearings, they would not budge. The axles are new 31 spline Yukon axles and the bearings are timken 514003's. We used a press with a lot of pressure (see the flexing in the picture). When that didn't work, we put the axles in the freezer. Still no luck, with either axle! We also compared the bearings to a bearing my mechanic had at the shop, and they were a match. The mechanic thinks that the axles are off, because usually the bearings press on no problem. Has anyone here experienced similar issues, specifically with Yukon 31 spline axles? I may have to see about returning the axles if I can.
