OK...thanks again for everyone's input...Here's what I know now, after pulling the whole thing apart. It's a large bearing - good. The bolt pattern is 3-1/2" x 2" That seemed weird...the studs are 3/8" So I guess it could be 3-9/16", but it sure didn't look like it...I was using a tape measure though, so I guess it could be. but that would mean it should have a 10" brake drum, and it's an 11" drum, no doubt. Just when I think I've got this figured out... ?:? . Also the axles are 28 spline, and 25" long on the driver side, and 27-1/2" on the passenger side, measured from the end to the outside of the bearing.
So then I notice that the holes on the bearing retainer plate look like they were drilled out cuz now they have oval holes...so maybe it used to be 3-1/2" x 2-3/8" bolt pattern and had 1/2" studs and someone converted it. So what would that mean? They took a 74-75 medium duty housing and used 76-77 axles and brakes?? Is there another simpler solution to how my truck ended up with this odd set-up on the rear end?
Anyway...that doesn't really matter...I think the brakes are from a 76-77...11" x 2-1/4". And that's all I really need to know to put it all together. Well, except for the axle seals...but I think I've got that figured out...they're the kind that are inside the bearing...so that means ball bearings not roller bearings then, right?
Well, I need new wheel cylinders, so maybe if can track some down on Sunday, I can get this thing wrapped up this weekend. Thanks again for everyone's help.
