What size is this plug? I removed them but can't find them anywhere to match them up at the hardware store?
What goes into these threaded holes (one on the timing cover and one at the rear of the block?
Was going to verify TDC so I can check my lash but the piston stops I bought won't reach nor will my compression tester. Is there an adapter to reach down into the spark plug hole? Also, now that the engine is buttoned back up, it's very hard to turn by hand using a socket on the crank bolt. When I was about to start the rebuild, I could turn by hand quite easily. to observe the internals operating. I've read this is normal for a fresh rebuild - what do ya'll think? (All new bearings and rings, new cylinder hone, reused pistons, arms, crank, cam. Had heads refreshed using existing parts except new valve seals and valves/valve ports lapped.)
