chuck
MnkyBiz said:Chuck,
I have your serpentine kit as well as an the old version of the Vintage Air setup.
I will be mounting the AC condensor on the driver's side.
You mentioned the need to modify? Will I need to be modifying a setup that I haven't even installed yet?
Or, will I just need to get some hard lines to run around the block????
MnkyBiz!
The compressor mounts on hte drivers side. I have adapter brackets to mount the Sanden compressor to the S-belt bracket that is in the S-belt kit so that part is easy. The V-belt set-up was a lot more trouble. The condensor and evaperator will work, we just made them work like they were made to be in a EB.
