A-Pillar question 66-67_68-77
Lt1Burb
I removed the A-pillar off of the 77 Bronco I am working on and pulled the new one out of the box. Well as it turns out it is a 66-67 because it is different. Will an early pillar work or should I sell these and buy another pair.
rydog1130
I know the B pillars are different because the striker post location is different. I think the A pillars would be similar but not 100% sure...
Rumcustom
This was discussed a bit on the thread that you were on the other day.
https://classicbroncos.com/forums/showthread.php?t=307537
They are different but not in a way that affects the door hinges, door gap, etc. They will work as A pillars for your bronco. If it were me I would get the correct pillars for the bronco that you are working on so that they mate up to the rockers correctly.
