? About ruff starting when it gets hot
BLUE72
I just got my Bronco back after two months. Everything is new now. Motor tranny, everything. This morning it started fine and after making a couple of stops I noticed as the day went on the motor became harder and harder to turn over. Finally I stopped had the battery tested and alternator tested and everything tested good. So I went home pulled into my garage turned the key off but the motor sputtered a couple of times before it shut down. I tried to fire it up again and this time the starter would turn but would not fire. It sounded like it was not getting enough power and the battery was dying. Finally, what felt like the last crank left, it fired up. I let it sit for a couple of hours went back out started it again and this time it started but the started cranked 4-5 times before it kicked over. Could this be a timing issue or a bad starter? Any help would be greatly appreciated. The motor is a rebuilt 5.0 carborated. Starter, coil, optima battery are brand new.
jpalmer
Boise, ID
As long as it is turning over semi-quickly it shouldn't be the starter, I would think timing. Just housekeeping stuff, but be sure to check that your distributor has good +12V and is tight. If you have a timing light, I would check timing too...
jpalmer
Boise, ID
Another thought, check for spark when you are cranking it and it's not firing up. It could also be a carb or other fuel delivery issue as well.
Viperwolf1
electron whisperer
Check the cable connections for looseness or corrosion.
SteveL
Huge chevy guy
Hawthorne ca
What kind of rebuild did you do? If it's a beefed up motor this isn't uncommon. The motor is always harder to start when hot. Heat expands and parts are tighter. Also with a new motor parts are tighter until broken in. If your battery and charging system are stock that could be part of the problem. High torque starter may help. Both of mine with built 351w's become a little harder to start when running errands but will crank over. It could also be some of the things stated above.
broncnaz
Probably a combonation of things the wrong timing can put a strain on the starter and now its getting weaker. I'd lean towards timing and grounds first.
75bronco08
sublimity,oregon
do you have header? seen where starter gets to hot and does the same thing as you stated.was the starter replace with new motor?if not could be part of the problem along w/cables.also do as others mentioned
B
BLUE72
Today I had a buddy check the timing. It was a little off but not to bad. I just put new ceramic headers on it when we installed the AOD and Atlas. I did have the shop put a new started in it as well. It still strarts after sitting and cooling down but after driving it for a short period it still will not restart unless I let it sit for some time. I also have noticed I have lost significant power. I am starting to think it is a fuel problem but not quite sure. The new headers are putting out a ton of heat so it could be the starter but I am leaning toward the carb leak and may be a combo of timing. The motor just seems to not be firing correctly. I know an AOD will take some power out of the motor but this seems like it is almost flooding it with fuel. I have a new Edelbrock carb on it with a BC Broncos fuel accumulator and a new BC Bronco tank. Thanks for the responses I will try again tomorrow.
