willtel
- Oct 3, 2003
- 594
I'm thinking about upgrading my ignition system to use a small ECU to allow for programmable timing curves and Ford EDIS coil packs. To do this I will need a trigger wheel for the crankshaft.
I know there are crank trigger kits available for 302s but I'm not sure if they will work with the odd Bronco crank pulley.
Has anyone added a trigger wheel to the stock pulley or used a crank trigger kit on a vbelt system?
This is what I want to use.
http://www.autosportlabs.com/megajolte-p-41.html
