While the typical install for the booster is from the intake, either through a single cylinder runner or a common area, it should not matter if you want to hook it up to the base of the carb. I've never used a carb fitting for a brake booster, but as far as I can tell, as long as it's full flow and not regulated by any restrictions, either location would be fine.
