Adding Power Brakes - Vacuum Question
redwards69
Double Oak, TX
Is it better to use vacuum port on intake or back of carb, or does it matter? PCV is attached to front of carb as it should be.
jckkys
The factory used a vacuum tree behind the carburetor. It splits to both levels of the 2 plain intake. The front PVC port was only used on the '76-'77s but in makes a more sanitary plumbing arrangement for the PVC and breather.
redwards69
redwards69
Double Oak, TX
Thanks. I probably should have noted nothing is stock, but I guess it doesn't matter. It's a 302 with an Edelbrock Performer 2121 intake and an Edelbrock 650 carb.
jckkys
On a Performer the vacuum tree would go in the hole on the top of the cylinder #4 runner. The PVC port is in the front of the AFB as you said.
While the typical install for the booster is from the intake, either through a single cylinder runner or a common area, it should not matter if you want to hook it up to the base of the carb. I've never used a carb fitting for a brake booster, but as far as I can tell, as long as it's full flow and not regulated by any restrictions, either location would be fine.
gr8scott
I run mine off a vacuum tree on the back of the carb. That yellow hose (pcv) has been relocated to the
front of the carb. She was robbing too much vacuum from my booster.
The PCV is a continuous flow. You want that at the base of the carb to evenly distribute the vapors to all the cylinders.
Brakes is just a momentary demand. Going to a single cylinder will be just fine. You might be able to pull just a hair more vacuum off a single intake runner as the vacuum pulses can peak higher than at the common plenum area. So over the course of a few revolutions of the engine the vacuum (via the check valve) may build up a little higher that way. That one cylinder may run just a hair lean for a couple of revolutions, but you will never notice.
redwards69
redwards69
Double Oak, TX
Thanks. Anyone have a link to a fitting that will fit my manifold (Edelbrock 2121)?
