Acording to every good reference manual I have read, it goes to the “S” or”Sta” post on the alternator. That is the stator post. That way the choke only opens as long as the engine is running.
If you hook it up to the coil or the “I” post of the solenoid, you pull an additional voltage drop across the ballast resistor and that lowers you ignition performance. There is also the problem with the choke warming up and starting to open if you turn the key to run, but don’t start it (or it stalls while warming up and you don’t restart it right away)
The stator terminal powers the choke while the engine is running, not relevant to the key postion. This may not mean anything right now, but the cold winter day that you turn the key to run, but the truck doesn’t start right away. Then you accidently leave the key on while you hook up the battery charger to give it a little extra boost. Then it won’t start because the choke has opened while the engine is still stone cold, you won’t want to be the one out there diagnosing the problem when it is –5°. If the choke was only hooked up right, then the little boost would bet you started and you will only be cursing the battery, not the whole truck.
