After drop down trac bar bracket repair ...
ared77
After drop down trac bar bracket repair I had to slightly pull the trac bar toward the left (drivers side) to reattach to bracket. Now my steering wheel is slightly turned to the left. This is on my '66 with lift and all aftermarket suspension/steering parts. My question is "Should I move the steering wheel about one tooth over or use the trac bar adjustment to make it slightly longer to fit bracket?" I think I know the answer and need to slightly lengthen the trac bar but want your opinion to be sure. Thanks in advance. Norm
bax
Old Member
I would adjust the track bar to get my axle centered. Then deal with the wheel if needed.
Wild horse 75
BC
What Bax said. I would add don’t just pull the wheel to center it. Make sure the steering box is centered. Also when measuring for axle centre do it at rest after rolling back and forth to ensure there’s no load. And measure to the frame not fenders. Ask me how I know.
And if the box is centered with the steering wheel, you don’t move the steering wheel. You need it centered on the box as your point of reference.
The adjustable draglink you have is for centering the steering box.
The track bar is for centering the axle of course, so you’ll have to make sure the axle is in fact centered. If it already is, then adjust the draglink if there is any adjustment left.
It does look like at least the upper is threaded all the way in already.
Is that the case?
If not, then, always use the draglink. That’s what adjustable draglink is for.
I realize the change came after tweaking with the trackbar, but if you didn’t adjust it, what else did you change that could’ve affected the steering box?
ared77
ared77
Thanks guys, just got back from driving it over to Lexington Cars & Coffee...with my '67 Mustang Jr in tow!
Couple of weeks ago I noticed the trac bar bracket had flexed slightly and started a small crack near middle of side of frame rail. I made up some new 1/4" flat plate repair pieces that now weld to the original bracket but also run up to top edge of frame, etc for more strength. Only thing that changed I believe is after repair the hole trac bar bolt passes through may have been a fraction of an inch out toward drivers side from before the crack appeared.
