Please pay attention to how you use it. It's water cured so you must wear a respirator else it will cure in your lungs. It's self leveling, but pay attention to your temps as it will effect the finish. I used a brush on the frame and went over the same spot a few times and it left some brush marks, so if you use a brush, don't continually go over the same spot. Try a roller instead. If you decide you want to use a spray gun (which I did for the rear bumper, the floors, roll bar,and the wheel wells) get a cheap HVLP gun from Harbor Freight for $10-20 and toss it when you're done. It's a lot easier then trying to clean it.
I'm pleased with the results. I sprayed a piece of scrap metal and when it was dry I hit it a few times with a hammer. It left a dent, but didn't affect the epoxy. To remove it to weld required an angle grinder with a sanding disk. As noted above, the epoxy isn't UV resistant. I didn't bother to coat the frame with a top coat that was, but I did do my bumper and roll bar with their blacktop.
