jspurl3
I have been having trouble with my ignition, first it would crank and run as long as the starter was turning then when I let off the key to run it would die. My mechanic said my ignition was not stock it was an electronic ignition with this module on the driver fender (Maybe called a TFI Module??). He replaced a bad wire and put a new one of those modules on it. It ran fine for about 2 days until I gave it some gas merging on the interstate and it died completely everything (lights, ignition, etc) I brought it to him again he put a new "module" on and it ran for about 3 blocks and died... Now it turns over just wont crank! Should I just trash the whole ignition setup and get something better (if so suggestion) or is there a cheap fix??? Sorry for the excessive details, I just want to be descriptive as possible.
Thanks! I am clueless when it comes to electrical
