- Aug 23, 2007
- 24,335
Another question though:
Isn't the resistor wire typically between the switch and connector in the engine compartment? I'm getting batt voltage in "run" at the engine connector but only 5ish at the coil. This seems to indicate the resistor wire is the red/green section from firewall to coil (which would screw up the full voltage starting provision, yes?....though I haven't had starting problems). I have a '73 pretty much all original, would this be a normal possibility? Also, the connector is toast...anyone know where to get a new factory type connector?
The reistor wire is under the dash near the switch. You should get full voltage when the switch is in the START position. The brown wire from the starter solenoid I terminal is connected directly to the red-green wire to supply full voltage, but only when the starter is engaged.
Try napa for the connector.
