Air Cleaner Options
Rangerbj
What are some options for air cleaners on top of a V8 with 4 barrel carb that DON'T hit the hood. My stock air cleaner hits the hood and pushes down on distributor.
Is there a product out there that could maybe have a "cold air" induction system that would work?
Thanks for the help
tabyers
Indiana
I use a drop base and a filter lid. They make off-set drop bases too so you can get around carb and distributor issues. All the other intake adapters and tubes I tried didn’t seem to get enough air. I found a drop base on summit, full size 14”? Filter lid, 3” filter and it all fits 302, high rise intake, no body lift.
tobyw
I'm working through a similar issue and happened to find the factory air intake horn for a 5.9L Jeep Grand Cherokee (ZJ) is a perfect fit on the Edelbrock 4bbl carb. The intake tube is about 3-1/8" OD so now I'm looking for a simple adapter to be able to run a typical 3" or 3-1/2" cone style filter over the passenger fender.
R
Rangerbj
Thanks for that information. Do you think you will have any restriction on the intake air?
Eoth
You have a pic of your setup? A "stock" air cleaner shouldn't be touching your distributor and its about as low of a profile as you are going to get (see Pic). There are plenty of low-profile air cleaners out there that "should" work but want to see what you have installed. If your intake is really tall, that will be a problem.
Here is a good thread for you to read..
https://classicbroncos.com/forums/showthread.php?t=263315
TDubya
Fortuna, CA
Like Eoth said, your stock air cleaner should work and not interfere with the hood unless you have a high rise intake manifold. I have an Edelbrock drop base air cleaner atop an Edelbrock Performer and Holley 4160 and have no clearance issues, but do have the small cap distributor.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
As others have said, a stock EB air cleaner doesn't come anywhere near the distributor. If yours is pushing the distributor down, it's highly likely you don't have a stock EB air filter.
jckkys
Do you have any idea what vehicle your "stock" air cleaner was made for? With a photo we would likely be able to at least say that much.
tobyw
I honestly don't know, but I figure if it was good enough to feed a factory fresh 360cid V8 it should be good enough to feed 302cid of worn out FoMoCo ;D
