Air or Electric?
mortimersnerd
I'm going to buy a reciprocating saw to cut a hole in my dash for my ARB switch plates. I'll likely get something like this:
http://www.harborfreight.com/power-tools/reciprocating-saws/electric-body-saw-65766.html
They also have an air powered version:
http://www.harborfreight.com/air-tools/specialty-air-tools/high-speed-metal-saw-91753.html
Which one will do a better job? I'm leaning towards the electric one as I think it will have more torque and won't have an air hose attached to it. I'm also planning to use whatever I get to cut my fenders when I get new flares.
bknbronco
North Metro, MN
The first thing i was thinking was how many strokes per minute? Although having a slower saw one would think you could cut smoother and more percise, but im thinking the opposite may be true. I believe that once you learn to control the saw the faster one will tend to be more accurate. The air one i think says i has more strokes per minute.
I have used a sawsall at work forever and have learned when to go slow and when to go fast. Most of the time a faster moving blade with less pressure is better than a slower blade. Im interested in what other think as well.
blubberfet
Reading the reviews it sounds like the air one likes more than the 3cfm@90psi. If you have a compressor that will keep up I would say to get the air one. But the electric one would work as well.
Amac70
ME
can't say about the electric but the air one is gutless. there is a reason the cp and ir ones are over a hundred bucks. I would go electric.
deltarat
Drew,Ms
I've used the air one. I did a lot of cutting with it doing my dash. It did strip the screws after a while. If you aren't going to use it much, it may be ok. If it is going to see a lot of use, I would go with something better.
Steve83
For cutting metal, you need LOW speed & a lot of force on the blade, with oil for cooling if you're cutting thick stuff. The air saw is great for wood & plastic, but not metal (even with a metal-cutting blade). Even decent body sheet metal is too thick for it. Maybe on a ricer's tin-foil body, but not an old US truck.
Get the electric.
kancox
I would'nt buy a recip that was'nt variable speed! For that small stuff you might consider a dremel tool with a wand and thin cut wheels,very controlable.
Pedestrian
Bronco Missionary
I cut all four fenders on my fullsize, transmission tunnel on my EB and FSB, all with the $7.99 Harbor freight air saw. Yes it is a cheap gutless wonder that sticks all the time, but it does work. It makes great cuts when you learn the limitations.
broncoitis
For what it is worth, I would use either a dremel or a jigsaw with a metal cutting blade with a 20+ TPI blade. Nice thing about the jigsaw is that you can find one fairly cheap that is variable speed.
That being said, I think that given the choice I would go with the Dremel hands down for working on the dash. You only get one shot at making the hole the right size and the Dremel is easy to work with and one of the best tools to have around if you don't already have one!
My .25 cents! ;D
