Air ride bronco
Boss Hugg
Does anyone know of a bronco running on air springs? The thought crossed my mind the other to replace my BADLY WORN OUT leafs with a four link system and air springs...
How would the air springs work on trails?
jckkys
I don't know arid New Boston is, but here in Tucson air bags dry out in a few years. All the Lincolns, Grand Marquis, Crown Vics, etc. here have to either get new air bags or better, coils. I put coils in my Grand Marquis when the air bags puked.
bigjhoov
nobody
Dennis H has a buddy in Illinois with a Bronco set up that way. His name is Brad.
The thought has crossed my mind. Even went a learned a lot about the air bag suspension. Local source here in AZ (Air-bag-it) is where I got my parts at for a different build. I converted a torsion axle trailer to air ride. That was a huge success.
For a Bronco I would only consider it for a street ride. You can't get the stroke out of an airbag that you can with a coil or a leaf. I looked at making linkage that would get more wheel travel for a given stroke of the air bag. No clean way of doing it. Everything would look like an overly complex SEMA build, lots of flash to make something work that has no business working.
Back to the street idea, if that is your route. The air suspension is progressive, very progressive. It will not behave anywhere near what a linear single rate coil will act like.
Thinking you can do an air lift kit? Yes, you can over inflate the bags and max out the height. But they get rock hard when you do that. Air bags have a happy height. Pretty much the natural height of the bag is where you should set the ride height. There is a little flexibility in that range, but get outside of that and the ride goes away.
As for ride quality, use the biggest bag possible. the bigger they are, the less pressure needed to get ride height, the softer the ride will be. Rarely will you go too soft, in which case a smaller bag can be put in to stiffen things later. Usually difficult to make the room for a larger bag.
Tune the suspension off ride height, not air pressure. Pressure based systems are only good if the weight of the vehicle never changes. Never carry cargo. Never have different number of people riding in it. My trailer is height based. It has a good ride to it regardless if it is empty or if it is loaded with concrete bags from Home Depot. I have pressure gauge on it. Was working on converting the pressure scale into a trailer weight scale. I didn't have a way to incorporate the tongue weight into it and squirrel...
Expect to want a small sway bar in the back. Leaf springs have a little bit of natural anti-roll characteristics to them that you will loose with a linked suspension. Since this is really only good for street applications anyway, some sort of sway bar would be good. Ram trucks went to link suspension (air or coil) and got a rear sway bar at the same time.
How are you planning to control they system? If you think you are just going to air up the springs with a tire chuck, it isn't going to work. They are not air shocks. Plan on a compressor. And a control system of some sort. The trailer I converted used a custom built (by me) Arduino using a ride height sensor. There is a pretty good learning curve in making your own. And you will want a 3-channel system. Left front, right front, rear. If you try a 4-channel system there will be internal fighting as diagonal corners spike pressure or drop pressures trying to twist the chassis when on a twisted piece of ground.
Mounting the bags will actually be the easy part of the job. The control system is the complex bit. The few good systems (with ride height) were way too expensive for what they were. All the cheaper systems are pressure based (pressure sensors are cheap to use and don't require any skill to install). But pressure is only relevant to ride height if the load is constant.
On my trailer I have an air chuck next to the pressure gauge. Allows for quick filling with shop air. Don't need to power up the controller. You can watch the pressure gauge build pressure, than the pressure rise drops off and the pressure remains nearly constant. This is the point the suspension rises to ride height. If you keep airing the pressure gauge will start to rise rapidly. This happens as the ride height nears full left of the bags.
As to how they would work on trails, I would say pretty poorly compared to a good conventional suspension. With as much as I like the air suspension I built. And what I learned to make it work. And plans to use it again in other projects. It would not be a choice of mine on a bronco for trails. But it might go on a street ride...
Boss Hugg
Boss Hugg
That's some good input there. I can see the bags limiting travel really quickly. And I would control it just like you suggested with3 channels, except I would make it really complex by having a switch that opened it to four channels for crawling so that you can shove that front tire down for that moment of security to keep from flipping forward. (Or any similar situation). But as I said the bags would reach max droop quickly and make for for limited travel, so I think the air ride idea is out.
However, there is the possibility of a street only rig in the future....but really what's the point of a bronco only driven on streets???
blingcoln
Carli makes long travel bags and so does airbaggit. It will work great with a little fab or just run 2.5 airshocks with a little tuning.
Air Bag it is where I sourced my bags from. Just checked to see if they have anything that is longer travel than what I looked for a couple years ago. Still the same. The "long travel" bags still are not that much travel. Mostly in the 10" range. But remember that they are progressive, and that full range may be achievable, but not usable.
thorgan
Here's mine...
I'm very happy with the articulation. Successfully ran the Rubicon a few years ago and we're going again this summer. It's fun to watch the reaction of the Jeepers when I lean away from squeeze rock on the way up Cadillac Hill.
The bags are by Goodyear. Here's a listing for them (I've made an effort to find places where I'll continue to be able to source them). They're rolling lobe as opposed to the single or double convolute that most equate airbag suspension with.
http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=16266
As you can see by the listing, they are about 12" travel and, in my geometry, I've got them choked up a little. That way I get a lot more than 12" of wheel travel in an articulation situation.
Broncobowsher is absolutely correct that the bell shape of the "piston" that the bag rolls over creates an extremely progressive spring rate. The result is a lot of stored energy when you hit a big bump and compress deep in to the travel. I was at Pismo Beach several years ago and was coming off of a dune where the transition from the dune face to the flat was very abrupt. The suspension compressed and then rebounded so dramatically that the Bronco actually bounced off the ground! I could see it clearly in my tracks where I paced off about a 10 foot gap. That was when I decided to make my own bag pistons with no bell shape at the bottom.
I then added some Light racing bump cans and they've really proven to be a game changer. I can now hit big bumps without fear of bouncing off the ground and losing control.
I've installed the straight rate pistons and bump cans in the front but have yet to do the same to the rear which still includes traditional rubber bump stops.
I've also installed a front sway bar since the design of my front end has very little roll stiffness. The bar is from a circa 1997 or so Dodge 1500 4x4.
I plan to install a very light sway bar in the rear to get the limit handling that I want out of it. I'll do this at the same time as the rear bump can and straight rate bag piston installation. Then I'll be able to remove the rubber bump stops as well.
The bags seem to be pretty reliable as long as you don't overcompress them. Due to small air leaks here and there, my Bronco eventually loses pressure if parked for more than a few days and, before I installed the rubber bump stops in the rear and the bump cans in the front, the bags were definitely overcompressed when the system lost pressure.
These bags would probably not work without going to full-width axles unless you get really inventive with your installation.
There really isn't a single thing that I dislike about the air bag suspension. It was a lot of work but I've ended up with better ride quality and better performance in every situation I've had it in. I've even loaded it up pretty heavily and the bags have proven to be quite useful. The rear Protofab bumper is pretty heavy to begin with and I had to use a fairly long 12" extension to get clearance between the bike in the following picture and the racks. But, with the bags, I just had to add more air pressure (maybe 40 psi rather than the usual 30) to bring it back to level.
As far as controls go, I use four industrial 5-way pneumatic valves typically used for controlling air cylinders. The valves are located between the front seats and I have four gages indicating the pressure in each bag. The air source is a York compressor driven off of the engine.
A future project will be the installation of an Aire Jax manual air valve set. I've had to rebuild the industrial valves and it was a pain. Hoping the Aire Jax will be more serviceable.
http://www.airejax.com/four-play/
Boss Hugg
Boss Hugg
So now i'm thinking about the trussed outer links with air springs mounted in front of the (rear) axle. That should take a bag with a small travel and HUGE progressive rate and spread that rate over more travel. Am I onto something?
thorgan
As a matter of fact, there was a time when I kinda wished that I had designed my suspension more like what you are describing, especially since I'm only using 30 to 40 psi in a set of bags that are rated for up to 100 psi. My current geometry places the rear bags about 4 to 5 inches in front of the rear axle and the front bags are a little more offset (maybe 6 to 8 inches) but to the rear.
Yeah, you're onto something. The trophy truck guys do it all the time but with coil-overs instead of airbags. It keeps their shocks from having to be 7 feet long to accommodate the huge rear travel they get.
Another airbag setup I've seen uses the bags to vary ride height and handle changing payloads along with a set of traditional springs (coils or leafs) for primary spring rate. One version of this is the add-on air ride that is so popular with the trailer-towing crowd but can be designed with a linkage like you're describing. I've never been very impressed by the add-on airbag kits because of the fact that they actually limit wheel travel. A typical pickup truck has about 8" of intended wheel travel by design (they may get more in articulation) but the double convolute air bags found in the kits usually exhibit only about 6" of usable stroke.
One final note about airbags that never seems to be captured in the aftermarket is the ease with which you can vary the spring rate. Here, the spring rate is a function of the volume of air inside the bag. The shape of the piston can be modified for different spring rates based on position but you can also remove air volume by adding measured amounts of antifreeze to the inside of the bags and affect an increase in spring rate. You wouldn't want to take this too far for fear of hydraulic locking the bag with too much antifreeze but you can fine tune. I never did this with mine because I measured the natural frequency of my setup and it wasn't too far off from a comparable Jeep baseline.
garberz
Bronco Influencer
Conejo Valley, Ca.
thorgan, you did a fantastic job setting that up! It's very unique, and it looks like it works quite well!
My buddy runs two bags on top of coil overs. This system he made himself and it works amazingly well. Three link up front and uses a sway bar on the highway, the rear is still leafs. This was done about 15 years ago and he hasn't changed anything since.
Mark
5001craig
Here's mine...
Thank-you Sir for sharing what you did and how you did it!
Craig
Boss Hugg
Boss Hugg
I'm thinking the trailing arms wouldn't do well in a hardcore rock crawling situation and here's why.
Running coil overs, you can put the lower coil over mount inside the arm, where it will align below the center line of the link mounts on the ends of the arms. This keeps the arm stable side to side rather than allowing for twisting motion which might cause things to bind up and possibly break. (this may not be a concern, but it's all in how well you design the system.)
In order to run air springs, the mount has to be a large flat area which has to be on top of the arm, or it could be sunk inside the arm like with a coil over setup, except this still requires a large flat area for the air spring to sit, which would make the arm wide and fat. This causes problems in the rocks because the arm would bottom out more (as if it were a skid plate) on high points pulling the tire off the ground, which stresses the drivetrain to keep the vehicle moving forward....
I've thought about cantilevers and such, but in a vehicle with a rear passenger/cargo area left intact, there's just no room.
unless someone has any other suggestions, I'm left to assume that air bags really are best left for most street applications, but could be (and probably are) used fairly well in racing.
TonyPDX
Here is what I did with air bags... I really just wanted a way to compensate for load changes. Once I added the rear bumper the rear sat low, especially if I put the hard top on and towed with it.
The way I have these mounted they do not limit my ~14" of suspension travel. I did plumb the bags separately to individual dash switches so I will have to try leaning away from the rocks on Cadillac Hill this year...
