all important miles per gallon
bluegt1987
albuquerque
i know this has been covered a billion times but i am trying to get a list of stuff to help you fuel economy and what they cost post anything you know from k/n filters to 5.0l swaps)
k and n filter $20-50 %5-10 mpg
headers $100-500 %5-10 mpg
br0nc0xrapt0r
Loves pickles
First post and no introduction my my, well weight reduction always helps aluminum rims fiberglass parts ect.
brixter
Tuolumne CA
I pretty much figure that the only way I will ever get decent gas mileage is to go two hundred miles down a hill steep enough to coast the whole way.
Gas mileage and Broncos seems to be a like oil and water ... they dont mix !
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Buy a Honda Civic and not a Bronco. I don't care what you do to an EB, you're not going to get much more than 15mpg.
B
bluegt1987
albuquerque
sorry
guess i have just been bugged by the 13mpg
names travis and i just scored a 1967 bronco 289 3speed
its got a james duff 5.5 ultimate and all kinds of litle stuf (including no top or windows to my disliking) i traded a 1999 jetta with 148k on the clock for her to :)
but this is my daily driver and i drive 34 miles a day so i am hoping to get a little beter economy until it warms up enough to ride my triumph again so any cheap ideas for fuel economy?
Amac70
ME
Hook it to a semi everymornig going the right direction. What size tires, what gears? If you have more then a 33 inch tire no mater what your set up i don't think you'll get better then 15 mpg. I can get 15 if i try, mostly get 13-14 and most would consider that pretty good.
jboomer
Havelock, NC
I'm getting 9-10 mpg. I drive about 10 miles to work, no faster than 40 mph. Stock tires, no lift, 302, 3-speed.
Scoop
Bronco Old Fart
Cuchara, CO
First, welcome to the site and congrats on picking up the Bronco - I feel sorry for the guy that got the jetta!
You'll love everything about the Bronco, except the mileage! You'll end up spending LOTS of money and gaining very little in economy. And if you are always worried about mileage you're not going to enjoy the Bronco. Best bet is to enjoy it for what it is - a 4WD aerodynamic brick! Best bang for the buck is probably a good free flowing airfilter, change your oil often, and easy on the driving.
An EFI and an OD tranny swap will help too and it will also improve the driveabilty over the carb and stock 3-speed. Most people do these for better off-road ability, not mpg - but 1 or 2 mpg gain is a nice added bonus to the swap.
luvmybronco
Ashland, Oh
Actually, I get about 21 highway on my yellow one...As long as i'm cruising at 65....In O.D. @ 55 mph my rpm's are @ 1500. Unfortunately, I don't drive it on the highway much...In fact, I rarely use O.D.
Yellow 68 with 5.0/AOD w/ 4.11's & 33's fiberglass roadster...
My red 77 get's half of what the yellow one gets, but it's more fun to drive.
77 302/3 speed edlebrock 4 barel w/ 3.50's & 35's and all steel...
sprdv1
REBEL
Congrats & welcome to the board..!
br0nc0xrapt0r
Loves pickles
where do you live and what triumph do you have?
Apogee
Tangent, OR
13 mpg is nothing to sneeze at...I get 11 mpg or so from a 351W with a 670 cfm Holley T/A, 3-speed, 3.50's and 33's.
Those percentage gains I consider VERY optimistic.
The numbers have been run before. It is usually more economical to get a little beater econobox for the dialy stuff and keep the bronco as a toy to be enjoyed regardless of operating cost.
It is hard to push a bard door through the air economicly. lifting the rig just pushes more air and offroad tires are harder to push. Lots of things will have a much larger effect on economy then air filters and headers.
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
I was getting 9mpg with stock 302, 2v, auto and 33inch tires. My autolite carb was dumping gas into the engine and I had a fuel line leak at the frame by the rear tank.
So, I added an edelbrock performer intake and 500cfm carb, Summit (k&n copy) air filter and I fixed the fuel leak. I'm now getting between 11 and 13!!!! WOOHOOOOOOO!!!!
I'm blessed. I live .8 of a mile from my office.
BTW - mine has never been on the highway since I've owned it. I'm trying to rebuild the steering and suspension before I do anything crazy.
needabronco
Prescott/Farmington
If your worried about gas milage why did you get rid of the Jetta? I had a Scirrocco that averaged 27 and a GTI that got 28. My scirrocco is still motoring around with at least 300k on it...
Past_Miner
I get about 12 on the highway...at 70-75 mph. I get about 9 in town. Even when it was basically bone stock with the OD tranny I never got much better than 15 out of the 351. I had one once with 31's, stock 302 and the OD 5 speed that would reliably get 18 on the highway, unless the wind was blowing against me, or there was a hill, or any other obstacle. Okay, it only got 18 when I was driving across Nebraska or someplace equally as flat.
I would look for a dirt cheap Geo or some other pregnant roller skate that is practically free to own and load the miles on it instead. By the time you actually add up the daily fuel bill the added costs of having the second car will not look that bad.
bmc69
Heck..I get 11 mpg on the highway running a built 408EFI and 39.5 IROKs with no OD..just a grany 4-gear and 4.88 gears in the diffs. That is driving her easy to get maximum mileage. The point...that it takes a fixed amount of HP to push these old boxes through the air at speed, period..and engine efficiencies at that required poer level vary little from one to the other and alos has littel to do with displacement..HP produced/required is same for a given speed regardless. My 408 is presumably operating at some high max efficiency with the EFI 'puter keeping it on tune..a carbed 302 might get worse mileage because tis not computer controlled. But there is no 'magic bullet' that is going to change the aerodynamics and rolling friction of these bricks we are so fond of.
Maybe design and build a fancy ground-effects kit like the ricers have and put that on?;D
jedblake
Boulder City, NV
Here is a way that I'm sure someone on the site can help you with, trade for an in-line 6
I'll I can say is that trips to the gas station are a lot cheaper than a monthly car payment. My EB averages 12-13 (302, edie 600cfm & intake)
Jed
