- Mar 18, 2017
- 189
I went a different route with the heater hoses on my 72 and they turned out really good for under $25. The first one that goes up to the heater valve I used a Gates 19045 which curved right around the valve cover. If you cut it right you can use the other half to run up to the intake fitting. With the preformed bend in the hose it will clear your carburetor electric choke and air cleaner. The second hose I used was a Gates 28472 from the core to the water pump. I ran it along the wheelwell with a couple clamps. As you can see in the pictures it puts the valve about perfect height with the cable and lined up great.
