Alternate solutions to the belt traction issues are larger diameter alternator pulley, or dual groove pulley, or both.
I'm only talking about slightly larger, so not a big deal.
What year Bronco? What engine? How many other accessories? A/C and power steering? These all change what you do to achieve the dual belt setup. It's what I did originally, but back then did not have power brakes or air-conditioning.
I had a nasty squeal with just a 70a alternator, so it's not just about sheer output capabilities on paper.
Other truck is running a 105a version of the same alternator and with it's larger diameter factory pulley has never squealed, even with a single belt.
A very slight advantage in this regard does go to the 1-wire setups. Waiting for 1200-1500 rpm before energizing, it's just the little extra chance the speeds all have to catch up to each other before the big load is placed on the belt.
If squealing was the only criteria then, this is an argument for the 1-wire. Personally I still prefer a standard multi-wire regulator type, don't mind the extra wiring to take advantage of their strengths, and will go to the other lengths to keep the belt from slipping.
