jerrybromley
- Sep 17, 2018
- 344
So I am firing up my 67 bronco for the first time after a 3 year major renovation. I used basically stock alternator parts( 1G with a voltage regulator ) factory brackets
During break-in I had what I thought was a bad squealing belt.
After break-in I pulled the alternator belt and started it up there was no squeal. So I bought a new alternator and installed it. It had the same squeal as the original alternator...OK that's weird
To continue troubleshooting I removed all the wires from the alternator and put it back in and the belt back on.
This time no squeal
Is it possible the voltage regulator is demanding like 110% of alternator output and causing belt slip ?
This time no squeal
