Tamnative3
- Joined
- Feb 12, 2026
- Messages
- 71
I had my alternator tested and it was bad so I go a rebuilt one installed it and when I checked it with a multimeter it showed only 12.4 volts with the truck running at about 2500 rpm. I figured that I got a bad one and took it back for a replacement and asked them To check it before I took it. He checked it while I was there and it passed so I took it home and installed it, same issue 12.4 volts.
Now I checked all the wires from the alt. to the regulator plug and all were fine, I also replaced the regulator just to make sure but I still just get low 12 v readings, am I missing somethin. Changing these is a real bi&@! and this is the 3rd time I have done it so I trying to figure out what I did. I was expecting 14.xx volts am I wrong?
