Yes, the '67 would not have had a stator wire, as those were only used on Broncos from '73 to '77. But the Painless should have had one in it, if it was the Bronco-specific harness.
Is this a Bronco, or generic harness?
Either way, all you need is BAT and FLD and GRD to make things play nice together.
The Black w/yellow wire runs up into the harness and around the cabin, feeding all the goodies before coming back out as the Black wire that charges the battery.
This is the wire that has the Maxi-Fuse (60a I think?) holder and might be Red in this case.
So, three wires to the regulator, three wires to the alternator, and you should be good.
As long as they're the correct wires!
The field and ground wires are the only ones common to both. The regulator gets the S wire from the ignition switch, the regulator gets the A wire from the battery, the alternator and regulator are connected together by the wire between the F and the FLD posts, and the wire between one of the case bolts or GRD studs and one of the screws holding the regulator to the body.
