American autowire 66-67 light switch
camp9k
Does anyone know if the AAW harness light switch connection reaches the 66-67 location on the far left side of the steering wheel? Centech notes that there harness needs to be modified for these years.
John
Sorry I'm not in the office to pull one out of the box and check for you. Will try to do that on Monday if nobody can confirm.
I would think that, even though it's not necessarily designed to fit all years and all configurations, that since it's just zip-tied together in bunches you should be able to pull the light group apart enough to let it reach. It's "only" about 10" or so, correct?
Of course, it's those last couple of inches that tends to get us in trouble!
Good luck. Hopefully you'll get an answer, but if not I'll check Monday.
Or, if you already have yours you can check yourself of course. Have wire cutters will travel!;D
Just checked one out and I can't imagine that you would not be able to make the headlight switch connector stretch to the full left margin of the dash.
Here's an image showing the ignition switch section to the middle-right, the headlight switch connector to the middle-left, with the fuse box and associated bundles at the far right for reference.
I didn't bother to actually measure, since it looked to be so long.
Hope that helps.
