Amp meter/gauge bouncing like crazy
MattM
Missoula, MT
When at idle my stock amp meter bounces back and forth from D60 to C60. It bounces so fast I can hear it peg from one side to the other and the needle is a blur.
When I’m driving (1500 RPMs or more), it wiggles a little from D10 to C10. And it always stays near 0. It never shows a constant charge or a discharge reading.
Do you know what’s causing this?
My battery will go dead after 5 or 6 days of no driving and I’m wondering if the amp meter is draining the battery. I see about a 1 amp constant drain when not running. (Or a half amp drain when the radio is unplugged.)
Any ideas?
Matt
The ammeter itself is not capable of drawing current (at least as far as I can tell) since it's a passive inductive device.
But it sounds like it's telling you there is a drain somewhere.
By all your symptoms though, I'd say your voltage regulator has done regulated it's last volt-age.
Even though they can be tested, if you don't know it's history, or know for a fact that it's fairly old, I'd just replace it and see what happens.
The drain AND the oscillating gauge are both potential symptoms of a bad regulator.
Wouldn't hurt to check all the wires and connections in the system at the same time you're replacing it though. Lots of things can get loose and/or corroded over time.
Especially grounds!
Oh, and even though I haven't seen one over the counter for a long time, it's possible that the old style "points" type regulators are still available. So when you go in to get another one, specify a solid-state type.
You can tell the difference mainly with the height of the cover. The more modern integrated circuit type are a much lower profile than the original points type. The same footprint, but roughly half the height.
bax
Old Member
Ok I must need a voltage regulator.
