So I've searched the forums and found some great info on the amp meter but what is happening to me isn't what I've read. My question is kinda simple, with the engine running (new 100amp tuff stuff 1 wire internal regulated alternator but made for the bronco) and I don't get a + after starting it just sits at 0 but when I turn on headlights I get the needle down to -10 or so, and it stays at -10 while the headlights are on. Turn the headlights off with the motor running and back to 0. Ive got a centec harness to my aftermarket gauge. I also notice the needle go from 0 to negative when im driving in the day with no headlights, but when the blinker is on or I'm hitting the brakes the needle drops down to the - side and when I let off the brakes and/or turn off the flasher it jumps pack to 0. So with the flashers on you see the gauge go tick, tick, tic, to the neg side while the lamps are being lit up. So should the amp meter needle dip to -10+/- when u turn the lights on and then make it's way back to 0 with the lights on as the voltage regulator picks up the need for more juice and delivers it? Or should it ride below 0 all the time you are running headlights? Or flicker to the neg side with flashers/ stop switch? I hope this isn't too much of an annoyance to more experienced people than I but I would really appreciate the help so I can use that gauge to monitor the battery draw/charge. Thanks
