Rockrawl
Hey everybody,
I finally got my CAGE arms on that I bought with the mass buy deal. When I did it I moved the axle 3" forward. I was actually shooting for 2", but somehow ended up with 3 and it fits fine ;D I'm going to need to trim the inner fender but that's alright. For those that are interested, I moved the track bar bracket on the frame 1" forward, used the WH track bar riser on the axle, and moved the lower coil buckets back 1". So far it looks like this worked out pretty well. The passenger side especially has very little lean on the coil. The driver side has the upper coil tower welded on further back than the passenger side so it has a little more lean, but I think it'll be alright. I do have a couple problems to solve that I'd appreciate some adive on:
With the Cage arms and 4 degree caster bushings my pinion angle is essentially parallel to the ground. This gives a pretty steep angle even at ride height. Any suggestions on what bushing I should use? Can I turn the 4 degrees over or will that be too much? I have a set of 4's and 7's but I have a feeling you guys are going to say use a 2. What do you think?
My other problem is it looks like with much droop below ride height that the CV joint on the t-case side of the front driveshaft will bind. I need to get my front driveshaft lengthened anyway, so what should I do about the CV? I haven't looked at this closely yet but it seems like a single joint at each end may work better? Would I have to change the t-case yoke to do this? I haven't looked into this very hard yet but a push in the right direction would be much appreciated if anybody has some experience/ideas on this.
Thanks guys,
Thanks guys,
