70 Steed
- Sep 13, 2011
- 268
I have just spent the last hour reading all of the alignment threads but still have a question. I have a '70 that has a Dana 44 swapped in by the PO.
I just got the alignment printout. The camber is .5 degrees on left and 1.6 degrees on the right. The alignment printout says the range should be 1-2 degrees. So I was thinking the right is ok and the left needed a shim to bring it closer to 1.6. But then someone posted that they like .5 degrees so is the left ok and the right needs to be brought closer to .5?
The printout says the caster is 1.0 degrees on both the left and right. I know I need closer to 4 degrees. I have a 2 1/2 lift. The WH catalog says for that lift I need a 4 degree C bushing. However DirtDonk recommends 7 degree bushings for all lifts. I don't know what degree C bushings I have in there now. Is there anyway to tell?
