Another Flowkooler waterpump bites the dust
blade
Maker of sharp things
Santa Fe
I used to rebuild machines that used a similar type of bearing to a water pump bearing. With a press you can rebuild a water pump. The weep hole is there to let you know that the inner seal has failed.
lars
lars
Been here awhile
NorCal flatlands
Speaking of weep holes... I removed said failed pump yesterday. In the case of Explorer pumps, there is a pressed-in plug that looks like a freeze plug in the casting below the shaft. There's a notch in the bore that it's pressed into. That's the weep hole. Just parked, engine stone-cold (it was 45° out) there was a steady drip coming out of it.
I pulled my junkyard pump off the shelf, an actual Ford part, and tried turning the impeller. It felt like new. Gave it a good scrubbing so it looked less old, and installed it. Haven't driven it yet, but unless the seal is blown in that one I expect (hope?) it'll be fine for awhile. Maybe I'll get lucky and it will be like my last one.
If I completely run out of things to do (anyone who knows me will agree that's highly unlikely) I may borrow my neighbor's press and attempt to dismantle the FlowKooler pump for an autopsy.
nvrstuk
PNW
We all know that it's not necessarily running out of things to do, but it's all about life's priorities.
So we are expecting a full autopsy on that flow cooler pump within two weeks!!
If not, put down the margarita, turn off Sesame Street, and get back out to the hanger/workshop! :) 😁
We’re doing something similar right now on a Jeep forum, where one of the members is dissecting a cheap imported mechanical fuel pump and hoping to compare it to known good USA made pumps.
Finding the failure/fault points to 3-D print some prototype new ones and make diaphragms out of better material. Starting with Viton.
Of the bearings posted above, I wonder if the one with the combination of ball and roller bearings is the stronger one?
This should be interesting!
