Another Coolant Capacity/Drain Thread
bostonbronconut
Question Asker
Wayland, MA
I completed an intake manifold gasket replacement and have been running regular maintenance on the truck to get it prepared for the driving season, which included swapping out a lot of hoses. I flushed the radiator with DEI Radiator Relief, ran the engine for 15 - 20 minutes, and then emptied the radiator. Thinking it was empty, I then added one gallon of Prestone coolant and one gallon of distilled water and it was already topped off. I ran the engine for a while to burp it in hopes to free up some space but the coolant level didn't go down.
My research has shown that the coolant capacity is 3+ gallons but I've barely put two gallons worth of fluid in. Is there a proper way to drain the radiator other than just opening the valve?
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Does your heater put out heat?
I believe so. When I flushed out the system, I opened the heater control valve and checked that it was opened. But I did close it when I turned off the heater and I think it was closed when I emptied the flush/water mixture out and when added fresh coolant/water. Could have fluid gotten trapped because the heater control valve was closed during emptying and filling?
Just draining the radiator through the lower drain will usually leave a lot of liquid in both the engine block and the heater core and hoses. Even though the heater core is not that big to begin with, added to what might be in the block and I can easily see another gallon at least.
Lots of ways to drain the block, but pretty sure none of ours came with a petcock like the radiator. Might be a plug at the bottom of the coolant passages, but I've never messed with one.
I've only flushed water from a hose through one of the heater hoses to make sure all the old stuff was out of the system, then sometimes even tried compressed air into the system.
While the compressed air did net a lot of extra liquid I don't know if it was all of it, or just what was able to be pushed around.
About the only other way I can think of would be to point the nose of the truck WAY down before you drain. Which is not always feasible.
Because the engine is basically tilted down in the back, even doing it on level ground will probably leave a lot in the system.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Do you think attaching a pressure tester to the overflow tank or the radiator will do it? I have one that I borrowed from Auto Zone when trying to find leaks.
I think that would be a great idea. No fiddling with sealing things up for the pressure.
You really only want a few psi anyway, but not having to use three hands while standing on your head and looking sideways at it is a real bonus.
After pressure builds, take the lower hose only partially off to keep the pressure from releasing too fast, and I imagine it will push all the water out pretty good.
I used to run the engine for a minute or two and let the pump do it, but the pressure cap seems a better idea all around.
The overflow tank would not be as good because not only is it plastic and can burst, but you'd have to get the pressure past the radiator cap anyway.
First time I've seen that one. Glad it worked out for you.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
I did a combination of hooking up the pressure tester and jacking up the Bronco from the back axel and was able to get a bunch of coolant out. I am also going to take one of the hoses off the heater core to see if there is any coolant stuck anywhere.
I've seen the Eastwood funnel system before (or one like it). I never bought one because I didn't want to spend the $20 for something I might not use more than once. I'm kind of kicking myself for being a cheap-@ss.
73azbronco
Wife bought it for my birthday, how she knew who knows. I looked at it and thought great, another shelf filler. But, pleasantly surprised, it worked great, now alas, its a shelf filler again till next engine rebuild.
