I believe I'm not the first.
For a few months now I've been trying to pretend that the coolant drip on my shop floor under my Bronco wasn't real. But it is, and in the last several days it's gotten so bad that it leaks even when parked. Out the weep hole on the pump. Maybe a quarter cup of fluid onto the floor just sitting parked, over a couple of days. This is an Explorer style pump. It's not the only problem I've had with it. Two gaskets were required to keep the impeller clear of the timing cover. Bought new from Wild Horses in September, 2020 (I'm not blaming WH). Less than 8k miles.
My last pump was an OEM Ford Explorer 5.0 pump sourced from a junkyard, I put over 120,000 leak-free miles on it, bolted to the front of my previous Explorer 5.0 motor. Betting Ford never expected their engine assemblers to use two gaskets to get the pumps to fit.
I understand new OEM pumps are made in China. I have another junkyard pump on the shelf, thinking I'll put that one into service.
