77RHINO
- Feb 22, 2011
- 308
I've got a question for the wiring gurus: For as long as I've had the bronco, only one low beam headlight worked, but they both worked on hi-beam, so I just drove it that way (I rarely drive it at night). This past week I put in a new dimmer switch, headlight switch, and nightlighter harness from WH. Now, when I pull the headlight switch out to the first click, park and headlights come on. They stay the same when I pull it out to the 2nd click on the switch, but kill to just the parking lights as soon as I hit Hi-Beam. The hi beam indicator will come on, all dash lights work, but no headlights, just parking lights. I have put new grounds at all 4 corners, and can't figure this out.
Also, only the drivers rear sidemarker works, even though I just put new bulbs in all and they all have worked in the past.
On a brighter ;D note, I did fix my reverse lights that have not worked since I've owned the bronco. PO clipped the wire inside the taillight corner which I discovered while working on the grounds.
What are yall's thoughts?
