- Oct 25, 2016
- 960
Hi all
I have purchased a used intermittent wiper set-up from one our great suppliers. It’s the used 1980’s F-150 type and it was sent to me “repinned” to work on the early Bronco. I cannot get the slow or intermittent functions working, but fast wipers seems to work fine. When I test using an OEM two speed switch instead of the intermittent switch, both fast and slow work perfectly. Is there any reason for this besides a bad intermittent switch?
Some other details - I have the Centech harness installed per the instructions, and have the blue, red, white and black wires spliced together to a 73 OEM harness and wiper motor. On the harness end toward the wiper switch, I have the wiring pigtail with the Centech wires arranged as per the attached diagram. I have read the articles on repinning, and to me the repinning appears to have been done correctly. I do think I have good grounding.
I did note on the TBP site that they state that the used intermittent switches are not compatible with Centech or Painless, but have seen that it’s been done countless times here. Any ideas appreciated!
