Another It Doesn't Start Issue
bostonbronconut
Question Asker
Wayland, MA
I've been tinkering with the '77 getting it ready for the summer. Most recently, I've installed a powered sub, which I incorrectly connected the remote wire to the ignition instead of to the amplifier; all audio connections should in the right place now.
Why does this info matter? The engine started with no problems prior to said subwoofer tinkering. A member on the FB BONES group thinks I've blown an ignition fuse but I'm having zero luck finding said fuse.
I've checked the wiring and the battery looks charged; there is fuel in the carb. The only thing I've touched recently is the ignition switch but it looks like everything is connected properly. I've included a link to a video so you can see/hear what is going on when I try to start the Bronco.
Update: I have the stock fuse box in my glove compartment. I've pulled all of the fuses and tested them with a multimeter and they all seem to in good standing (i.e. not blown).
Thank you for your time and help!
https://youtu.be/708ZtE80RHo
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Have you found your fuse box yet?
That's first place to check
I was just updating my post when I got a call.
Yes, I have the stock glove compartment fuse box and it looks like all fuses are good. I'm going to retest in a moment just to be thorough.
Timmy390
Conway, AR
Guessing not a fuse issue as the rig will crank. So you have power to the ignition switch and in start position you have power to the starter solenoid
Check for power on the + side of the coil
Tim
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Tim
This is where my inexperience becomes a deterrent.
I turned the ignition switch to On and set my multimeter to 12V; I poked the positive side of the coil and I got nothing - I also poked the negative side with the negative probe and got nothing.
Was this the right test?
Timmy390
Conway, AR
Guessing all stock....so Duraspark II as memory serves
Coil wiring is key on/in run 12 volts (well about 7 volts because it's got a resister) to positive side of coil, then the negative coil wire goes to the Duraspark Box. During cranking, the coil gets full battery power from the "I" post on the starter solenoid.
If you have no voltage at all in the key on/run position that would be an issue but I would expect it to start when cranking then die when you let off the key.
Check voltage at the coil during cranking
Tim
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Tim
I'm going to grab some alligator clips so I can hook up the multimeter while cranking. In the meantime, I did swap out the stock coil with a Standard FD476 a year ago: https://www.summitracing.com/parts/SMP-FD476.
Rustytruck
on your multi-meter meter set to DC Volts. Ground the black lead to the engine block red lead to the positive on the coil. key on around 7 volts key twisted to start should be battery voltage. from the starter switch in the run position there is a resistance wire from the start switch to the coil + that drops the voltage in the run position. In the start position the wire is bypassed to the starter solenoid and runs battery voltage to the + on the coil so hotter spark when cranking.
While it's a good thing to pull the fuses, clean them and put them back in every few years anyway, there is no fuse in the stock Bronco panel that protects either the ignition switch OR the ignition coil.
Just for giggles you can pull the small Brown wire off of the "I" terminal of the starter relay on the fender to se if you get 12v there with the key in the ON position. If not, then you at least have confirmation that the power is not getting to the firewall connector (should be the red one behind the engine) either. So would indicate it's not an issue with the wires on the top of the engine.
You can separate the red connector too of course, but pulling the Brown wire is just easier!
With the volt-meter you can probe the ignition switch itself and see if 12v is getting to it via the Yellow wire. You can also (more easily) test the center post with the Green w/black stripe wire (you didn't connect a ground to this by any chance, did you?) which should show 12v in both ACC and ON positions. But nothing with the key OFF.
Just a few things to get you started tracing out what went south while you were messing about.
If it was the main fusible link on the Black wire (battery side of the starter relay) under the hood you would not have power anywhere. No lights, no heater, no nothing. So if all of those work, your main power feed should be ok at least up to the first splices under the dash.
By the way, have you tried putting some fuel down the carb throat? Almost sounded in your video like it wanted to start but did not have enough gas.
You said the carb had gas, but are you able to pump the accelerator lever and see nice squirts of gas coming out of the squirters?
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
I haven't had the chance to tinker around with the Bronco since my original post on 06/04 but I recently bought an auto voltage tester and I grounded it to the battery and then poked the ignition coil and didn't get anything. Wouldn't the pen light if the ignition was set to ON and there was power going to it?
So test some other areas. First, make sure the light works by going positive and negative right at the battery. Lights up, then great.
Disconnect the red 3-wire connector with the Red w/green wire near the firewall and poke the pokey end into the body side connection. Should see a bright light on the Red w/green port (should be a Brown wire there also) and perhaps a dim flashing light on the other two (temp and press sender wires).
If no light at the connector you need to go back to the ignition switch on the dash. You may find that your original resistor wire that feeds the coil has failed. It does not happen very often, but it can happen.
This wire may (or may not) be Red w/green at the back of the switch, or it could be Green w/red (they're the same circuit as far as the switch is concerned), or it might be a puke brown with extra thick jacket with printing to the effect of "resistor wire: do not cut or splice" or similar.
Keep on digging.
What it would not let me post first is:
Yes, you should see a light with it connected the way you describe.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Keep on digging.
Per your recommendation, I disconnected the harness and go NO light from the Red w/ Green but saw pulsing light from the other two ports. I checked behind the ignition and found a red-green/blue wire with the conductor exposed (see image). I also discovered a lovely yellow wire with a random splice that goes nowhere. :mad:
It is kind of hard to tell which wire is the red-green from the red-blue but I think the exposed conductor is the red-green.
I finally got to do this as well and the voltage pen did NOT light up when I poked the "I" terminal/brown wire.
Wow, those wires have seen better days.
The double-wire exiting the switch is your Green w/red and Red w/green. They share a terminal in the switch, so come out of the strain-relief together.
The Green w/black seems intact at least, but also shows signs of abuse where it appears to have been crushed, or maybe even over-heated to the point that the jacket got soft?
The Purple/Violet wire in the background is your dash mounted Brake Warning lamp circuit. It's connected outside of the strain relieve directly to the side of the switch. It's a "Prove-Out" location. That means that when the key is turned to START that particular terminal grounds out to the dash and temporarily completes the circuit for the lamp and it lights up to tell you that the bulb and circuit are working.
That other wire with the Yellow sticking out of the switch, with the Black sticking out the side, the Red sticking out near the bottom, and what looks to be the Red w/blue maybe(?) coming out the top needs some testing! And some help!
I don't remember which position is which physically, so can't say for sure what's going on. It does look like it's the correct position for the Yellow 12v feed wire. But that means that you're missing a wire. The START wire oddly enough, since this is a no-start discussion.
Here's a replacement connector/strain-relief with harness ("pigtail" that might help: https://www.wildhorses4x4.com/product/Ignition-Switch-Socket-Pigtail/Bronco_Wiring_Harness
It can at least get you started with fresh wire, but if you're clever with a soldering iron you can still probably make your old one work with some new wire.
Test the function of that bundle of joy on the right and let us know what you find. If it's the power feed your test light will illuminate no matter what position the key is in.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
The best those wires have looked were when the wagon left the assembly line.
I’ve already poked the wires with the voltage pen and didn’t get any readings. There is a possibility that I didn’t ground it correctly but I tried a bunch of locations and still nadda.
I don’t have a soldering iron so I’ll probably just get a new harness.
Gives you a new starting point at least. It's not a direct replacement for every year Bronco, but it fits and can be made to work.
It's an exact fit for the switch, and the correct wire colors come out of the correct places, but only a few years had an actual connector that would slip into the one on the new wires without splicing. And since yours has been mangled a bit already you'll probably be splicing them all in anyway.
Crimp connectors are good, solder connections are gooder (in some cases) but either one is just fine and better than you have now.
Because it's an important system component, good weather tight connections are best. Get some heat shrink tubing, or maybe easier some crimp connectors that are shrink-to-fit with sealer inside. Get you a good connection and a dry one that won't be subject to years of moisture.
But find that other wire!
And find out why you don't have power on one of the wires. Because if you are getting power to any accessories (try the heater blower for a test) then you have power to the ignition switch coming in from somewhere. If you need to verify a ground for your test light, run a separate wire extension all the way to the battery if you have to.
And speaking of grounds (which is something we do a lot around here) take a picture of the battery connections and where they all trace out to so we can look at what you have.
A common issue is that the person replacing an old tired battery cable neglects to re-connect the body ground and only connects the engine ground. Good enough sometimes, but not very reliable for running all the other junk.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
I do have power to the heater blower and other accessories; I'll try to trace back to find if something got pulled out.
I don't think that is the issue as the battery is relatively new and I've got a ground on the engine and the chassis. I took a look a minute ago and everything looks connected correctly.
Thank you for helping me troubleshoot this. Hopefully, it is just a simple solution that we've yet to discover.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Welp - turns out it was those two spliced green wires; they were just hanging out by themselves. I'm guessing the PO used any jacket color as the tech diagram I am using has those wires as red-blue, not green. I must have disconnected them when I was trying to get the ignition switch back into the dash when I completed my stereo/sub project.
Thank you for all of your help with this. I really appreciate it.
