ANOTHER - wiring question - brake and emergency flash switches
in2broncoz
Still trying to weed out my electrical issues and missing parts.. ( 1969 )
Question 1) im missing the emergency flasher switch (searching)..how is it wired? found a red w/black wire comming from harness, near ignition
Question 2) the brake switch had been rewired both red..there is a (+) label near one of the leads this comes from? and the other goes to?
Question 3) there is a red w/black wire near the turn switch connector (thinking this goes somewhere in the loop?)
Viperwolf1
electron whisperer
1) It has 4 wires going to it, one from the switched side of the brake light switch, one from each front turn signals, and one from the hazard flasher. It doesn't really matter which terminals of the hazard switch they go to. The switch just connects them all together when it's on.
2) One comes from the headlight switch. The other goes to the turn signal switch. Near the turn signal connector another wire should break out to go to the hazard switch.
3) It might be the one going to the hazard switch.
