MyOriginal66
- Aug 11, 2009
- 2,071
^what they said
update: I was getting ready to pull everything off and send back to fitech when i read the thread pipermike posted about. In it a guy talked about having a similar issue and was able to correct it by adding a direct ground to the tb itself. I added a ground from the tbi front passenger tb mounting stud and took it for a drive. Ended up driving 40 miles and didn't have a cutout. Hmmmmm? So i came back and pulled the ground off and drove it another 10 or so miles with no cutout. I got with kurk at fitech and am holding off on the return. I am going to wire in a permanent ground to the tbi and drive it heavy for the next week and see if the issue comes back. The fitech relies on the carb mounting stud for return ground and i'm wondering if it just isn't making a good connection all the time. I have solid grounds from the battery to the motor, battery the frame, and battery to the body. As well as a ground buss for the relays and fitech fuel pump. I will update this thread next week after puting some miles on it and let everyone know if the issue comes back.
Since I'm also on the above-mentioned thread/forum the ground thing is one thing we were curious about and a little surprised they were only using a carb stud as ground.http://67-72chevytrucks.com/vboard/showthread.php?t=605736&page=16
just read this extremely long thread about some of the problems a couple of guys were having with their unit, both went back to carbs, not what i wanted to hear as i am considering this system might sit back and wait awhile now. Hope you guys get them figured out, maybe there's something here that might help if you have done read it.
...Most EFI issues I have ever read about typically end up being a dirty power (fluctuating power etc.) or bad ground so I plan on eliminating that right out of the gate.
Grounded the unit well and have had a spacer in place since the beginning. Seemed to be doing fine till this morning. The first 20 miles nothing then doing 45 mph it starts losing power and I have to pull over and it dies. Let it sit for about 5 min trying to start it off and on and it finally fires up and goes for 50 miles more without a hiccup. I am totally stumped.
