bteutsch
- Jan 11, 2009
- 875
I let mine sit for over an hour while trying to re-start at different intervals then it got dark while I was still tinkering with it and I had to throw in the towel. I was getting fuel and the ecu was doing its initial "click" squirt of fuel so Im thinking its a tach coil wire signal issue. I will do some grounding and wire connection triple checking before I drive it again. Runs great otherwise.
Would it fire initially and then quit? Like run on the first squirt of gas for a second or two? I had a problem like that. It only did it when the engine was wet though. Ended up being the two wire harness that comes out of the back of the throttle body grounding when it got wet. Might not be your issue but when I found the plug sitting in a puddle on top of the intake. Took it out and fired right up. Tied it up out of the way since I'm not using it right now. I suppose it could be your coil or the tach signal. If it's the tach signal or no power to the coil you will also get a similar situation but it won't start at all, just turn over. You can tell if you aren't getting a tach signal using the hand held tablet. Go into dash board and turn the engine over. If it's getting a signal it will show up even while just Turing the motor over. I think it's the first category called RPM. If no RPM's register then that's a good place to start at the coil. What ignition are you running?
