mlogan24
- Jun 14, 2001
- 1,380
Hey Broncobowsher,
A little off topic-but since you're following this thread, I was going to ask. Would you mind e-mailing me your latest .btc shift files? If you can that would be great. I'd also like to upload them to the Yahoo AOD group's files.
Thanks!
As far as staying on topic-some figures were kicked around for cost, so I thought it might be helpful to give mine-
4x4 AOD-E/W $450
Baumann TCS $425
Valve body kit $100
AA AOD-D20 Adaptor $500
Labor to swap out 4x4 output shaft for AA output shaft FREEBIE! Zip Zero Nada (Did it with the neighbors help)
Ford Parts $30ish
Shifter $Free (column mount) to $180
So all said and done-figure $1500-1600 (I didn't add in misc. stuff and driveshaft shortening lengthening as that can vary from install to install) to put in an electronic AOD. For a non-electronic AOD swap, your core will be much less (NOTE: NON-ELECTRONIC AOD'S ARE BASICALLY JUST AS PLENTIFUL IN THE YARDS AS 700R4'S) and you can shave off the $500 for the controller of course. Figure adding in about $200-300 for performance upgrades on the AOD. Hope that helps.
As far as the 700R4 goes, like I said before, it also has some great features, but comparing the costs just didn't add up for me. Granted, the core is cheap and it's cheap to rebuild (NOTE: there is nothing magic about the 700R4's in stock form, I know several guys that have gone through quite a few of them just by using them hard but nothing crazy, so you almost have to do a performance rebuild on one). But once you add in the cost of a second adaptor (assuming you are using a SBF engine and a D20 t-case) you either break even or it costs a little more.
Thanks!
4x4 AOD-E/W $450
Baumann TCS $425
Valve body kit $100
Ford Parts $30ish
