cannunz546
Bronco Owner and Admirer
I will get you his name and number tomorrow.
The adapter plates are cheap and easy to find. I think I paid about $30 for mine. Just do a search for “York to Sanden adapter”. They are all over eBay.
Sanden compressors can also be found at decent prices. I found mine on eBay, new and in the box, for $75. You have to be careful to make sure you are not getting a Chinese clone. I called Sanden to verify that mine was authentic and under warranty. Then I bought the angled hose fitting that I needed and just replaced them so I am still using the old hoses.
Advance Auto has vacuum pumps and a/c manifolds that they loan out. I got those and charged it up. My total cost, including Freon, was about $150 to switch the compressor and charge it up.......
Great information Slowleak, thanks for posting it up and doing the legwork for us. Did you already have the compressor when you called Sanden to verify or were you using the info from the listing? $150 vs sweating = priceless!
You will need an adapter plate and a couple of hose fittings. It’s an easy swap. Your Bronco will also lose a few pounds...
https://jeepair.com/york-to-sanden-conversion-plate.html
Not sure where to go for the idler. The pulley is about 3.75 outside diameter. It’s offset about 1.25 inches from the mounting bolt so you can rotate it to tension the belt.
Since you're going with the Sanden compressor, why don't you get rid of the idler pulley? See how Slowleak has spacers to move the compressor back on the mount so the pulleys line up? Should be able to line it up with your alternator. That will get rid of one belt and pulley.
Your old system ran on R-12 and new compressor units run on 134 A. there is stuff they will need to do with the expansion valves to go to 134A. If you have 3 or four cans of R-12 sitting on your shelf you could refill with that. The oil in the compressor and the lines will have to be flushed and changed to go 134A. The old york compressor will probably need a shaft seal kit in it if you want to have any chance of keeping the R-12 in the system.
Before dumping wads of cash in the old R-12 compressor system I would run a vacuum pump on the parts and see if they hold vacuum. I would also talk to your local air conditioner shop to see what they recommend you do. You will also need to buy a new receiver drier too. Just allot of pitfalls resurrecting and old r-12 system.
Maybe you know all about this just pointing it out if you don't.
6 hours to install a Vintage Air system yourself seems really conservative, especially if you get into replacing pulleys, mounting brackets etc.. That will require pulling the radiator, fan, and a lot of old rusted waterpump bolts. That can go south real fast....
When I switched my ARA system over to R134, I didn’t change anything except the high and low pressure service ports, and that was just adding in the correct adapters. After evacuating and recharging, it cooled fine with the old York compressor. .
I didn’t have any leaks so I did not see any reason to change seals. Sometimes it better to leave older stuff alone if it is working.
Since it’s the first time testing it, you might pull a vacuum for 10 minutes or so, then let it sit for a few minutes to see if the needles move. If not, then proceed with the full evacuation. No reason to run the vacuum pump for a full hour only to find that you have a leak.
You can get the port adapters at almost any parts store. They are usually in a bubble pack right there with the Freon. Those are the ports in your pictures. One is high pressure, the other is low. The kit will have adapters for both included. Should be about $12
Not sure how much oil a York requires. Here’s a link to a manual that may help. You want to make sure you get the correct type of oil also....
http://www.240.se/litteratur/york.pdf
