00gyrhed
- Aug 3, 2006
- 2,428
The instructions that came with the ARB say to grind 2mm (5/64ths) of clearance between the ARB carrier housing and the pinion nose bearing housing. I looked a the pictures and cut it down by eye and removed quite a bit of metal before checking but I went as far as I wanted to go, but once assembled I only have .020". (.5mm)
Why, heck Ford didn't give the ring gear that much clearance at the back of the support. I only have .014" at the ring gear and the back side of this housing and I have.020" at the nose between the ARB carrier.
2mm is quite a bit more metal to remove and I don't really want to grind that much metal off that nose for no reason other than ARB wants to be sure it NEVER hits even when the silly thing comes apart. I loose a carrier bearing and the ring gear is going to hit hard long before this housing makes a glancing blow against the nose.
should I cut more clearance for both and give the ring gear more clearance than Ford did? possibly weakening the nose support even more? Or is this not a big deal?
