are front disc breaks with 33's an absolute must?
SaddleUp
Vancouver, WA
Let us not forget that even with a disk brake upgrade our lifted trucks still need more room for error when stopping. I.E. Do not think that just because you have disk brakes you will be able to stop on a dime every time. If you do then you are more likely to slide off the dime on your side instead.
meathead333
Alexandria, VA
i have drums and 33's. i plan on using my rig for basically a daily driver. maybe some offroading now and then, but nothing extreme. my question, knowing i just use it for a daily driver, which would benifit me more? a brake booster or a disc set? also if i were to get a booster, can it still be used with the disc set if i uprage to that later on? my brakes are good right now, but id like to make it a bit safer, but i also dont have a money tree.
ken75ranger
Troy, NY
Me personally, I'd go discs first.Then the booster. I'm not as concerned how hard the pedal is to push. I'd rather have to push a pedal hard and have it stop sooner.It won't stop any faster with the booster it's just easier to push the pedal.
meathead333
Alexandria, VA
ok, so maybe i was misinformed...the booster doesnt help stop you better, it just makes it easier to brake? and the disc brakes give you a faster, better brake? so if i were to get disc brakes, would i still have to push it to the floor to slow down unless i got a booster?? or how does it work? i was under the impression that the 2 dont work together.
roundhouse
I ran drums with 33's until I had to make a panic stop from 60 MPH towing a small utility trailer, after I bought new underwear, I did the math and since the disc conversion was less than my insurance deductable, I did the conversion.
If it saves you from bumping a vehicle in front of you, even lightly, its paid for itself.
